Jagged edge on text
One thing I hope to be able to do with my machine is to pay for it by making small engraved nameplates etc. Attached pic is literally my FIRST carve.
I noticed the edges to be slightly jagged. I used the 1/16 upcut bit, slowest speed on the 611, and the recommended cut settings.
To smooth things out my first thought was a slower feed rate, second thought was using a 1/32 bit (that I currently do not possess.)
Anyone have any more insight on this?
V-wheels a little to tight AND/OR belt tension to high?
Both could make the movement “jittery” because it need to overcome friction before motion is allowed.
Just a couple of cents worth :slight_smile:
A little better with the slower speed.
Thanks Haldor! I’ll check th V-Wheels. I have my belts all at about 3lb/1".
If you used Easel fonts zoom in on your design. I bet it is the font itself. I found that out the hard way.
