With the new workshop up and running now, the wife wanted some new bench pins for supporting thin sheet metal while she is cutting it by hand, sanding, cleaning etc.
Instead of buying one, I just made one instead. Trivial job, but there is something great about using a tool to make another tool.
Got a few different designs on the go and the wife will try them and will refine over time.
Design is just a series of shapes created in Inkscape and then âUnionedâ together to build up the design before outputting the SVG for import into Easel. Material is just 18mm planed spruce and carved using a 1/8" straight 2 flute bit using the Maple default settings.
Cheers
Ian
