JT laser tech focus thumb wheel
I received the JT laser and got it all set up during the testing phase i saw that you are supposed to carefully spin that metal ring to focus it and thought to myself . Self being as your are super clumsy this may not be a great idea to spin the focus ring with your fingers . Behold a safer way if you have a 3d printer .
oh your def correct , I thought I had it set on the lowest setting per youtube . But when it switched to the lowest setting it was no laser at all . still figuring the thing out
If he uploads the files, I would be happy to print one and send it to you.
I have a 3d printer and if you want send me the file and I will make it for you.
I meant to offer to print it for him also i mean its like 10 cents worth of filament , but when I upload the file it shows as gcode not a stl
jtechlaserfocus.stl (131.8 KB)
fixed.
And crazy name you say that is my mothers name
Based on the crazy filename, I assume you made it in Tinkercad. Can you share the project?
I have updated it with the correct STL . I am also going to share it on thingaverse. The wheel is a little large i scaled it down to 98% before printing buts its a very quick print so ymmv
