Jtech reset bottom question
Is there a way to remove the need to push the reset bottom on the jtech laser driver?
I am setting up a control panel with power switches to everything, and when i flip switch to kill power to laser, upon restarting I need have to hit the reset bottom each time.
It is on there for a saftey feature so it can not accidentally get turned on.
You could run the reset switch to the control panel to make it more convenient.
Would that just look like running a loop to my control board with a button off of these wires?
There is a connector for the remote reset switch. It is next to the fan connector.
Found the remote switch on jtech’s website. Looks like I’ll go that route. Thanks for the help!
