Just a question about these lines
Never mind, I am jut stupid LOL the dotted line were the max size this particular machine will carve - I have never done anything before larger than 7 x 11 - Thanks for the help - the blue line did go away when I turned off tiling
I haven’t used my Easel Pro in quite a while. I have this set as 12" x 12" x 1" because I will be carving on a board that is 28" long x apx 7" high(live edge) x 1" thick. It will be a wall hanging coat rack.
The reason I went 12x12 is to make it easier to center my long piece on the CNC - What are the dotted lines? Can I get rid of them and how and also the dark line at 6 inches. Thanks for any help here. - hope this picture comes through.
Did you turn tiling off or is it still on? I have limited easel knowledge because I use Rhino3d but I had similar lines and they went away turning Tiling off.
Thanks I will give it a shot - I was totally new to the CNC a year ago. Daughter and husband bought it as a gift so I am learning as I go
I turned the tiling off and the blue line went away but the dotted one is still there - that is the size of the last piece I did but when I created this file I created a new project so I wouldn’t think that would have carried to this one - No big dead other than that is just about where I need to center my carve - I am going to put a scrap piece in and test it and then “should” be good to go - thanks
