Large Dibond + LED
Hi there. I wana show my first large project. Dibond got 3.2m long and 80 cm height. I cut project in corel, export to svg and open it in easel. After that i cut one part, move dibond, cut 2 part etc. Then make some aluminium construction with pvc 8mm, led and thats all.
Nice work, great example of stretching the machine limits
Where did you get the material?
Also did you have the corner graphics printed on?
Way cool project.
It turned out great!
I print all graphics on oracal printing media. Then i stick they on dibond. To make corners i use some new Makita tool like that ( can be made by Festool PF1200 but is 4 times expensive )
That tool make some v-groove on dibond. After that you can bend dibond to 90 degrees and You make box from him.
Where i buy dibond ? strange question :slight_smile: i buy him from shop with dibond , pcv and others materials:) As i know Dibond is orginal patented material. I dont know how is in another country but in Poland we got many species of that material like TKbond, DuoBond, etc… but is stil the same aluminium - composite - aluminium but low cost. Orginal dibond is expensive.
Awesome.
I was thinking of seeing if I can use this material to create some nice signs where I live.
Thanks for the tip and info.
I am in the US btw…
Some my signs on 3 mm black mat dibond:
100 cm width:
3 mm dibond
3 mm dibond on black 20 mm XPS
In live :slight_smile:
Very nice work!
:slight_smile:
Thanks for sharing
