Laser goes too high
hello. i am new to this and have been using the fox alien 4040 xe for a few months.
when i press “raise the bit” the bit raises. then i readjust the level of the bit. but when i press the spindle, the laser raises again and burns my wood making a big burnt point until it starts to cut. but marqué the laser is too high it does not cut. and when it is finished it returns to zero point burning the wood in its path because the laser is still working.
i have a video as a demonstration. i hope to be able to solve my problem with your help
have you set $32 to a value of 1 as required for laser mode?
it will need to be returned to 0 for spindle mode also fyi…
