This is our Shapeoko 2 laser engraver. It’s not fully enclosed with laser safety shields, but it does serve it’s purpose to protect our eyes.
Which makes me think: you wearing your lighty tighties?
So what do you guys think about this.
I make a shield (like a suckit boot) out of the laser shielding material.
It would attach the same way as the dust boot (with magnets to the existing side arms)
Instead of a large hole in the center, just have a small 1/8 inch?? hole for the beam to go through.
Then maybe add a 3 sided box going up to the laser itself.
Any thoughts?
WOW…
Thank you.
That way one doesn’t have to worry about someone just walking into the shop and getting hurt.
@LarryM Hope this thread is still alive. I was laser engraving fine today and was switching back and forth between laser mode and spindle mode. I have grbl 1.1e and use Picengrave. After my second engrave the laser only engraves super tiny now. I reflashed and changed all my grbl settings to your post with 1.0c and still no luck. Any ideas as to what is going on? Here is the file I was trying to engrave
Cavs Sword.ngc (510.3 KB)
The G-code file that you uploaded only has tiny moves in it. All of the moves look to be less than 1.5 inches.
How did you generate the G-code? Make sure your settings are correct in that program.
I generated it in PicEngrave Pro. Its supposed to fit on a 3" x 3" coaster, that’s why the movements are tiny. It turns out my UGS had blacklisted the G20 command so it was just ignoring it and remaining in mm. I just went into options and removed the blacklist and just finished running the file. It worked! Thanks for your timely response!
This is the size your PicEngrave gcode file says it is.
( Image size in inches: 2.872w x 2.992h )
Is that the size it engraved?
Jeff, could you try this file with PicSender? I have run it through UGCS without error, but when I try it with PicSender I have problems ( versions 2.7.5 and 2.7.6) (my version of grbl).
Ok, Thanks.
Found the problem. Operator error.
Yep that’s the size I was going for. My issue was the G20 command being blacklisted. My machine was trying to carve everything in mm.
