Late to the party - Aluminum fidget spinner
Made this a little while back for my daughter, but it took my a long time to edit together all of the media.
This is an aluminum fidget spinner I made with a ceramic ball bearing. I actually made two… one with 3 “wings” and one with 2 “wings”
It’s well past the curve of popularity, but should anyone want them, I made the files available for free on my website ( chopbangbuzz.com )
Here are the basics of what went into it:
First I designed it all up in Fusion 360 and used Fusion’s CAM package to create all of the GCode and preview the simulation:
2 - fusion
3 - fusion
Here is the layed out drawing of the fidget spinner (for the fun of it).
I cut some aluminum stock I had laying around down to a size that would fit in my vise.
4 - cutting alum
Cutting it with a bandsaw, especially with the repetition and backing out/in for a better cut, meant I needed to clean up the cut edge quite a bit. I ended up clamping it to the end of my CNC table vertically, and squaring it up as best I could. It was the only way I could get the clearance needed to do this part of the milling:
Then I just slapped it in my vise and ran the GCode:
You can see it taking shape here. I noticed in the beginning it was cutting way better than this point, where it started doing more “pushing” of the aluminum. I attribute this to a variety of factors, but especially too shallow of cuts, and running my spindle (router) too slowly, leaving it under powered.
I found an affordable engraver! It actually works really well and is super easy to use. it’s almost magical watching it engrave quickly. I’ve already done some other custom stuff for people who wanted engraved keychains etc.
8 - engraving spinner
A flip and… well, the same as before!
9 - cutting spinner side 2
Final engrave on the other side. You can see how the end result looks compared to the fusion preview.
10 - final engrave
I glued the ceramic bearing in with CA (super) glue, which seemed to work really well. It was a fairly tight fit so the glue used needed to be super thin. I don’t think I can bring my machine within the tolerances needed to try the “freeze” method of bearing fitting.
My daughter seemed to really like it… and then asked me to make her friend one (which is why I ended up doing the 2-wing version… hate doing the same thing twice)
Anyways, as I said, the files are all freely available on my site: chopbangbuzz.com, and here’s a fun little video of the whole process:
Hope you like!
very nice. what did you end up using for feeds, speeds, doc and bit? your milled surface finish is very nice!
I don’t have it offhand, but I can try and dig it up for you.
One thing is I was running a .5" end mill, and only running my router at around 8k RPM, which was brutal on it. It barely made it, even taking exceedingly shallow passes to minimize the load on it.
I wouldn’t use a .5 End mill in the future, it’s just too much material for such a weak router especially at low RPM’s. I am sitting on a VFD and spindle that I hope to upgrade to as soon as I finish my mount design (Just need to figure out how i wanna do the eccentric nuts… or anything else like that for tramming).
However, today is wooden sword day! Hoping to have another video, models, plans, etc. out this week of that.
