Latest sign
Here was the last sign we carved… It is 60" long and made from 3mm brushed aluminum dibond® and stuck to the entrancewall with vhb tape
<img src=“//discuss-assets.s3.amazonaws.com/original/3X/6/4/64d2e0c93ac71d1257b69ea398412473a4610b3f.jpg” width=“690” height
Can you give us the specs on cutting dibond? Thanks.
Nice! How did you cut a 60" piece?
I went 20ipm at .0625doc using a .25" “O” Spiral upcut bit I was also using a Bosch router set on 4
I built a 5 x 8 table - it’s not that impressive - the Y axes is fine but the X still needs beefed up after installing steel plate mod - sometime it wants to bounce in the middle of the table -
I have posted pics before on here
here is a link to the thread Shapeoko 2 (Discussion,Assembly,Tweaks) - #36 by DustinNull
