Leaking lubricant oil
Hello, so upon using my new x carve pro about 5 times, I’ve noticed that my mdf board has about 6-7 oil drips on it spread through the table. I also got a drip of lubricant oil on one of my wooden pieces as I was carving. So what I am wondering is if this is normal or am I having a faulty issue in which I should get into contact with invetables? Thank you all
The first few days of owning my XCP I was noticing a bit of oil collecting on the bottom of the linear slides on the Z axis.
I just wiped it off with a rag. I never had it actually drip on the waste board though. I think this was just a bit of over lubrication at the factory. It will not continue once the excess has been removed.
