I am looking to paint a Board and then use my xcarve to carve out the letter outline and spray paint the outline a different color.
I was thinking to use masking tape on the board and have the x-carve cut through it using either a v bit or the 1/16 bit. Is masking tape the best to use or will it get into the bit and prevent it from cutting or cause the tape to come off the board?
Put a sealer on the board before you carve it, I use shellac on the board first, then paint it, then put Oramask 810 on it, some people use Oramsk 813 but I use 810 because it is for solvent based paints.
Good Luck
Russell
I have had good results using readily available Contact brand contact shelf paper. I seal with two coats of shellac and then lightly sand to remove roughness. Then apply paint. If necessary to get the surface relativity smooth I may lightly sand again. Then apply the contact paper making sure to firmly rub the entire area for good adhesion. I then use a Sharp 1/16" DOWNCUT bit to carve the outline of all the design elements. After that, I use a larger bit to clear the remaining areas of the two-stage cut.
I know some have not had much luck with contact paper but it works for me. I have Oramask but find it usually offers about the same result at twice the price. I have tried “Duck” brand contact paper and it was a fail. It’s adhesive just doesn’t stick as well and is thicker so tends to rip rather than cut.
