Letters overlapping
Hi, I’m on my second carve and noticed my letters are kind of over lapping eachother. Anything I can do?
That makes sense, I’ll retry it later and see if it happens again.
Are you using Easel? If so, you can use the Xploder app and add a small space between the letters …
Good luck…
Yes I’m using easel. The preview showed and gap so maybe I hit the wrong bit. Thanks for the info!
Did you cut outside your path? If so your bit will take up the extra space.
That makes sense as well. I’m still learning what everything means lol. Iill give it another go and pay more attention.
I think it was the font. I tried it again and made sure everything was correct and the same thing happened. Changed the font and worked fine. I guess I have alot to learn lol
