Can someone provide a thorough description of the sequence a machine using an X-Controller goes through when homing? I am using Kevin Pattersons hall effect sensors as limit switches and the X & Z axis seem to be working. I see the Y limit trip, but the homing sequence does not appear to back off and seek like the other two axis and the software never completes the sequence. I have verified the wiring several times.
- What should the voltage between the Y limit sensor line and ground be?
- Any thoughts on tests I can do?
