it is connected to the terminal second from the left. next to the right x axis limit switch
What if you swap left and right switches at the board?
i tried that, it did not work. the switch may be bad. i have some switches, will try and change it out to see what happens.
You could always reverse homing to home back right⌠Thatâs the default anyway.
None of my limit/homing switches are registering
Are they connected?
Youâll need to provide some more information.
Yes they were connected, what I found out is that the computer was not recognizing the xcarve. I had to disconnect the USB and reconnect and they all showed up. Thanks
