Lock scale ratio
Can you add a lock scale ratio check box in shape, So if your rectangle is 10 x 5 and you change (X) 10 to 20 (Y) 5 will change to 10. Should be easy works when you drag it, would be a lot more precise if it worked with typing the numbers.
I think you can hold down the shift key and drag. If you enter the numbers manually right now you would need to calculate the ratio yourself.
That’s a good feature request for @paulkaplan and @chrisbalin to add to the list. Seems like low complexity big reward for the user.
