I’m new to x-carve scene. I was just wondering if you glue planks of wood together to make a good size sign, will the bit be affected by the seams? I don’t want to spend the money on good wood and break a bit on a seam
I have glued boards together in a butt joint and milled through it without problem. I would not expect the glue joint to bother you.
