looking for firmware for a 4540 machine or something close in the machine set up
The machine setup within easel will push updated settings only to inventables branded machines. all “other 3rd party” machines will only have the work area settings generated and some bit cut settings setup. Soo if your cnc is not in the list, you can simply select “other” and enter the desired work area.
You’d want to test and edit the cut settings from defaults as you learn the cnc anyway, as the defaults are always very conservative… so yeah, just pick “other” and enter the work area and off to the races…
