X-Carve Pro is having issues homing. We’ve been using the machine for a couple years…works great. We love it.
Having an issue homing the machine. Y axis reaches “parking spot” then keeps trying to go further, with a griding sound. Then machine stops. X axis does not even come close to the limit switch, so it appears to be not in play.
- Machine is clean of debris.
- Tested all limit switches. All light green when pressed using the diagnostic procedure.
- Just being overly diligent, tested, removed and checked the X axis switch and bracket. All good.
Help! I have work to do and X-Carve is dead in the water. Thanks!
