Machine Zero in UGS
I am just starting to use UGS more now that I have V Carve Pro, thanks to awesome Inventables team. I tried to do Machine Home in UGS 2.0 last night. It did Z axis just fine, but X axis it keeps trying to go further left (-ive X) than the hard limit switch. Hasn’t gone past X so don’t know about Y. Any ideas?
Thanks
Munawar
Machine homing is sending a command to GRBL ($h) and running its built-in routine. It’s the same command that Easel uses to home the machine.
It does Z axis and then does X and Y at the same time. If the switches don’t stop it, then theres a problem with the switches.
Thanks Justin. I’ll run home with Easel tonight to see if it does the same thing.
