Macros Anyone?
I’d like to request the ability to create and run macros that will essentially behave the same as sending gcode commands in the command window. these macros can be assigned to an upfront easy to access view. One such macro would be to move the cutter to a specific XYZ position after cut is finished.
One such useful combination would be using a jogging feature to assign any current location to a macro. I would then select this macro once my cut finishes and the cutter would go to that position.
Thanks
you can already do that with G28.1… there are post if you search… but you are right… being able to run macros and subprograms would be great… also (I don’t know if this is already available using fusion-to-easal) setting multi work offsets… G54-G59
