Is there any way to maintain spacing between two or more objects as you resize them?
Specifically, I have two rectangles, one inside the other. I need to make multiple sizes of these two rectangles but always have them spaced apart the same fixed distance. I want the distance between the two rectangles to maintain that 3.5" when I resize the two objects regardless of the size of the rectangles.
Currently when I resize both rectangles they maintain the ratio between each other so making both smaller means the 3.5" between them gets smaller. So I’m forced to resize them one at a time
Anyone know of a solution? Thank you in advance!
