We have worked out a quick process for making exact copies of used gaskets that are NLA, in any material. It does get a little wordy but I will post it if anyone is interested.
I would love to see your process. I usually have to make several dry runs (on cheap paper) to get the dimensions exactly correct.
Always up for a better way.
Please share! Thanks
So here we go, this is my process using what apps I have
Measure the height and width of the gasket you want to duplicate.
Place on a flatbed scanner, scan the now .jpg file into my desktop, (d/t), scan folder.
Bring the .jpg file into photoshop elements, crop and click “save for web”
reduce pixel count by 90%, save as optimized. -
Open a file converter (I use Convertio) convert the optimized .jpg file to .dxf. then download to
my d/t, easel DXF folder. -
Open easel, import the now .dxf line drawing file into your setup. It will be too big to
fit until the next step. -
Under Edit, choose “select all” set the height and width from step one, set the cutting
parameters and export to my d/t, easel .nc folder.
7 Open my CNC controller (Candle) and import the .nc file. Setup and run.I buy packets of mixed gasket materials from my local auto supply store and fix them to a 1/4"
wasteboard with Spraymount.As they say, the devil is in the details, if you want a more detailed step by step explanation send a
PM though you will quickly find out what adjustments need to be made for your setup.
