Making your own powerful Controller on the cheap side
No. It serves as the motion controller. It interfaces directly to stepper drivers.
No doubt. Though some people are not familiar with command line and man pages :slight_smile:
Or my favorite, VI
Ok. So what would I need to go from straight demon to Mach 3. The interface on Mach 3 looks pretty cool.
:wq!
I like your CAD system (Cardboard Aided Design)
Technically, you just need a dedicated PC with a parallel port and a DB25 breakout board. You can wire everything else from the demon to it (I believe).
I think you’d be better off finding a better GRBL interface (for now) than wholesale changing to MACH3.
Nah - force the change through, your probably logged in as root anyways :stuck_out_tongue:
Hi all
I use uccnc for over a year now on two machines. Cnc and co laser. Started with Mach 3 bit they need parralel port of smoothie board.
Uccnc alsof need ethernet control Cars nut so fast and stable way netter and cheap er than Mach 3.
Grtz
They don’t have a gcode sender built into emacs yet?
I’m beginning to understand. Mach 3 utilizes a (db25) breakout board to control the (tb6600) stepper controller, bypassing the arduino and talking directly to them over PP or usb to parallel converter?
How does it send pulses and coordinate/synchronize the stepper controllers all at the same time?
LinuxCNC/Mach3 or 4 Basically operates as the motion controller. It directly drives the drivers and monitors all the I/O directly (i.e. Input devices like Endstops, Probes and output devices like SSR or VFD/Spindle controllers.) Far superior to AVR based motion controllers.
As for the DB25 configuration this a ‘common’ pin out. Not a huge fan of USB based controllers. But this is a Mach 3/4 thing. LinuxCNC does not support it (Officially, There are hacks. But I’d avoid them. Specifically motion controlling. USB addons for more I/O thats fine for thing like controlling a tool changer, vac. pump for a vac. vise or other light duty on/off tasks or status changes.)
5i25
 Configuration pin-out:
Mill Function   DB25    Mesa             Type             Chan     Function        IO
Spindle Enable   1      0   IOPort       None
Spindle Speed   14      1   IOPort       PWM              0
X Step           2      2   IOPort       StepGen          0        Step            (Out)
Estop Reset     15      3   IOPort       None                                      (In)
X Direction      3      4   IOPort       StepGen          0        Dir             (Out)
Charge Pump     16      5   IOPort       StepGen          4        Step            (Out)
Y Step           4      6   IOPort       StepGen          1        Step            (Out)
Coolant         17      7   IOPort       None                                      (Out)
Y Direction      5      8   IOPort       StepGen          1        Dir             (Out)
Z Step           6      9   IOPort       StepGen          2        Step            (Out)
Z Direction      7     10   IOPort       StepGen          2        Dir             (Out)
A Step           8     11   IOPort       StepGen          3        Step            (Out)
A Direction      9     12   IOPort       StepGen          3        Dir             (Out)
X Limit         10     13   IOPort       None                                      (In)
Y Limit         11     14   IOPort       None                                      (In)
Z Limit         12     15   IOPort       None                                      (In)
 Probe In        13     16   IOPort       QCountIdx        0        Idx             (In)
At any rate, both of those platforms use RTOS. Which can easily drive multi-axes machines with a crap ton of inputs/outputs. Especially setups with MESA cards (i.e. 5i25/6i25 or ethernet based units like the 7i92H/M) The MESA platform uses an FPGA that handles stepgen duties, I/O monitoring and encoders setups at a much higher frequency which offloads that task from LinuxCNC or Mach 3/4)
Side question is higher impedence in a stepper motor better? One is 2.8amps one is 3.0.
Angus I was just making a joke - Linux is just a whole other animal in itself. I’ve been a systems admin for 21 years, 17 was on *nix systems. They have changed for the better though, tried to become easier to install and use which is always good.
jer
Lower impedance is better.
They are similar, but the 3A one is better on paper. Due to the +/- 20% variation it could in fact be opposite :wink:
If lower impedance is better then lower amperage goes hand in hand. So I’m I’m lost again. :cry:
@PhilJohnson check this out.
Had it printed out for shifts and giggles.
23HS30-3004S
rated current 3.0 amps
phase resistance 1.12 ohms
inductance 4.8 mH +/- 20 percent
23HS30-2804S
rated current 2.8 amps
phase resistance 1.13 ohms
inductance 5.4 mH +/- 20 percent
variation in the 2804 = (5.4 * 0.2 = 1.08) range is 4.32 mH to 6.48 mH
variation in the 3004 = (4.8 * 0.2 = 0.96) range is 3.84 mH to 5.76 mH
I would go with the 23HS3004S.
Inductance (not impedance) dictates the torque curve. The torque curve is limited by the current capacity of the stepper. The lower inductance means it takes less drive voltage to optimally run the stepper.
The inductance does NOT always correlate to the current rating. They are two different ratings for steppers. You can have lower inductance and high current motors.
That’s a 3.5A stepper with a 4.1 mH inductance.
The 2.8A Has a higher inductance than the 3.0A one which means the 3.0A is actually a better fit for the 24V drive voltage of the Xcarve.
