We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youāve provided to them or that theyāve collected from your use of their services. Learn more.
Currently got it for all, even Z.
Was using the same step settings with the DRV8825 and everything was running smooth (until I had a similar problem) and I am definately not saying that this was correct, but it was working.
I am using a custom machine, hope thats not a problem.
Y-GT3-Timing-Belt 20 tooth, 6 mm.
Not sure if that are the stock pulleys and belts for the x-carve.
Here are my settings:
Only difference is that i got $102=188.976
Check your dipswitch. In the picture I noticed something off. You have it off on off. There is no such setting. The dips are reverse from normal on off.
I just finished my quick and dirty assembly of my controller. Should be ready to test this weekend. Provided that I can finish building my shed before the storm.
Okay, could not sleep last night and almost read this whole thread.
So I just gathered some more infos:
Motors 4x: Motech Motor, MT-2303HS280AW-C 1.26Nm, 1.8Ā°/step, 175 oz
Power supply: 24V 360W
Machine size: 1000mm x 1000mm
I attached a picture of the driver and of the motor description.
Some infos about my āsetupā. I have to admit that the cables are quiet short and
all are crossing each other. It is quiet messy.
Using 18awg cables from drivers to motors (through a drag chain) and 20awg cables from drivers to Arduino (R3) screw shield.
Currently there is NO cooling except the heatsinks. But the problem already occurs after 30 seconds of moving in the
air and it seems like it is mostly the X-axis.
Hope this helps a little.
And I just ordered 2x 120mm fans to make sure this is not the probem.
I was wondering if any of you kind intelligent friendly and may I say handsome folks could help point me in the direction of a power supply to drive 4 of the 269 oz steppers?
If the stepper driver only take 40V āpressureā then 48V will make it leak/rupture.
But if the stepper driver happily accommodate 48V āpressureā then the added pressure can provide more power at higher pressure levels, assuming same current capacity.
So for a CNC higher voltage is ābetterā but as Justin said, only if the driver can take it
Most of these cheap controllers use Toshiba chips. While some are TB6600 most are a newer surface mount chip in that family. That 40 or 50 volt rating is a max rating. Go above that and the chip will take damage. These are FET switching controllers. Therefore they are AC driven, Not constant voltage. The problem is switching transients can be much higher than the power supply voltage. There needs to be head room to protect the chip. The higher the stepper inductance the more switching transients can be a problem. Also, the higher the voltage, the more heat is produced in both the chip, caps and steppers. Toshiba notes this in the data sheet. I have been driving 3 385 OZ large inductance steppers at 30 volts for 2.5 years now and have not had any problems. This is with a Toshiba chip rates at 40 volts Not the TB6600 rated at 50. The web is full of people trashing these controllers because of failures. There seems to be a correlation with high voltage and failure. Give yourself some head room. Now there are some drivers out there that use discrete FET design and are much tougher than the single chip design. About 3 times the price compared to these at the low end. If you choose to drive these controllers at high voltage and they fail then Know that that was your choice.
thanks phil I have the same one, maybe Iāll pick up a second lol. Think by the time Iām done with the upgrades I have half the parts for already iāll be able to assemble a stock xcarve from the take offs.
Iām in the process of building a Phil style controller and am looking for some grounding advice from the electrical guys.
Iām using separate DC power supplies for the Arduino (9v) and the stepper drivers (24v). Reading up about ground loops, Iāve connected the grounds for the 2 supplies at the point plugs on the case only and run separate ground wires out to the various components.
Iām using stepper drivers similar to the photo in the post Iām replying to. On the signal side of the inputs I know I need to tie ENA-, DIR- & PUL- to ground, but should that ground run back to the Arduino or should it be connected to GND on the high voltage side of the stepper driver?
I have mine running back to the ground on the arduino. Why are you using a 9v adapter for the arduino when it will be powered by your computer when you connect it via usb?
