I just started using MeshCam to generate tool-paths for CAD STL files from Sketchup, then importing G-code to Easel to carve 3D projects. Process works fine although it has a number of steps. Since you can select various numbered tools in MeshCam, it would be awesome if it was possible to export/import one G-code file and have Easel stop for tool changes when the tool number changes in the file. I am no G-code guru and new to Easel so love to learn if this has already been solved or is impossible - Thanks
