Hi… does anyone have advice on how to get the machine to carve in the center of material? have the material squared. xy cornered and still image is off. I’m really unhappy with all the little glitch’s. They seem to be never ending
Have you created your project using the correct X,Y measurements for your material? If so, you can center the design on the material in Easel, set your carve to begin in the lower left corner, move your bit to the same lower left corner of the material and begin your cut. Don’t forget your depth and other settings you may need. The placement of the design on the material in Easel is paramount.
