type of material and cutting setting, since a few days ago no change of time and speed.
Why?
Hi,
I have the same problem: when I change the type of materials, don’t change the automatic cut setting.
Where is my wrong?
Thanks
Can you share the Easel file your seeing this with?
thank you for answering. I don’t understand which file I should show.
It’s a simple svg figure, the problem that I change the material remains the same cut setting.
So the actual Easel project, inside of Easel go to File > Share > Share with Link > Save, and then just copy and paste it in here.
For no reason now everything is ok.
Thank you all
