When I am entering a value in a text box like depth of cut, I want to be able to enter a fraction, then equals, and have it calculate the value.
For instance 1 / 8 = would change the value to 0.125.
Or, 0.125 / 3 = results in 0.042.
Basically, onkeypress, if the key is an equal, get the value, strip the equal, make sure it’s only numbers, period, and a single math operator, and then push it through eval(), then round to 3 or 4 places…
This is a standard feature in many drawing programs — no equal necessary. Freehand even respects order of operations and allows one to use parentheses to control that.
I have had many projects where I wished that Vcarve would allow me to create variables with assigned values (either a constant or an expression). Then when cutting multiples of the same project on different thickness material I could just change one value for thickness and all the other variables would adjust in the toolpaths.
For example if I wanted a pocket to be cut to half the material thickness, I could define the depth for the pocket to be “T/2”, and the profile cut would be at depth “T”
