Can you take any image from google to meshcam and make it 3D
hope this helps you out
MeshCAM works with your CAD
MeshCAM works with almost every 3D CAD program by opening the two most common 3D file formats, STL and DXF.
If you just want to make 2D parts without using a 3D CAD program, you can load 2D DXF files (in R12 format) and extrude them to a 3D part.
We’ve got lots of users of:
- Alibre
- Solidworks
- Autodesk Inventor
- OnShape
- Rhino 3D
- SketchUp
- Viacad
- Autocad
- Freecad
- OpenSCAD
- Tinkercad
- Blender
- ZBrush
- And many many more…
Normally you’d make a 3d model and then import that into the toolpathing software,… my using a photo, a software will have to use contrasts like dark colors vs light colors to try to guess heights to use…
And you get something like the results of this website does, which can then be imported to meshcam to make your toolpaths…
https://3dp.rocks/lithophane/
