This was my first tryto make a Middle Earth map on the X-Carve. I modified some pictures I found online. I took some attempts to make it work but, after a lot of broken 1/32 bits, i found the right configuration.
The frame is made of 100 year old reclaimed wood with its original paint on it.
Feel free to comment how make it a bit more detailed
Thanks guys. I tried it with the Inventables V Engraving Bit, but it didn’w work because the material is only 3mm thick,
I’ll do the next one as an relief on a 12mm plate, thats a great idea!
The map is, including the frame, 60/75cm or 25,5/30 inches
