Missing M3/M5 from g-code
We’re using Easel to create patterns to cut on our new Vevor s4040. We download the g-codes to a flash drive to upload to the computer that is connected to the CNC. We use UGS for cutting. For some reason, the M3/M5 and S commands for the spindle are missing from the g-code. We used the same process previously with our Sainsmart 3018 and never had an issue. Are we missing something with software with the new machine or does this have something to do with Easel drivers/updates?
Did you set up the machine through Easel and tell it you had a spindle? See about 2 min in.
CNC How-To - Setting up Easel for the first time (Machine Setup)
after going directly through easel and skipping ugs it does work also using manual instead of z probe is not the way to go . got that set up and am off to the races . thank you for your help . cheers.
