Yoo Da Man Dayuhm
Are the half slots there for a reason Phil?
I’m guessing because bits don’t drill square
Now im so bad at drawing/graphics that I asked my 3 year old Daughter to do this
Im thinking if that’s an exposed joint it will take a putty fill , fine if painting but such a cool joint should be exposed
If they were inverted would it work ?
Cheers Phil. its good to learn that about dogbones ,
and yes, the sawdust and glue trick is wise counsel (fistbump)
GC
Here is a free “Freemason logo” in PTN, STL or RLF format from CNCCRAZE.com
https://cnccraze.com/collections/free-patterns/products/freemason-logo
How would I add the other half of the dogbone to each piece? Could I then use contrasting colored dowels to pin the dovetails together for a dramatic effect?
FYI, I really envy your CAD ability
Really well done with the details… good work!!
That box represents a lot of carving time!
Love that box Phil. Can’t wait to get my hands on the 750 X-Carve
im guessing that the weights are holding the bottom plate/lid down while it glues up ?
edit----sorry Robert, DOH!!! yes the carvings are upside down, Start Over,!!!
well we dont do we @bobjewell
thats the value of Phil , who knows what you’ll get when you log on …
i dont think he sleeps !
i wish i lived closer , his shop must be awesome to hang out in,
i didnt understand the join cut with dogbones on cnc until i saw it assembled, @AngusMcleod , and not the test piece, i was still lost , but the actual finished piece, then the light bulb moment occurred,
a picture = 1000 words
I was literally just googling the best ways to cut dovetails on a CNC without having a vertical setup.
I really like your concept/design, but personally I can’t stand the rounded pockets in the corners. I wonder if there is a good way to incorporate dowel pins into the design that can insert into the pockets (sanded flush later) that add asthetic quality
Otherwise I think I would rather have the CNC cut the bulk out, and then just a little chisel work to clean up the corners.
BTW, those 3D carves came out incredible!
Im betting you have a small snow plough converted to pick up the foot deep dust,
how about a "show us your shop " thread,
Ive seen some pics on here of shops that are surgical clean , Xcarve robotic surgery anyone?
mine is a rammed earth floor so needs to be proper disgusting before it strikes me as needing ploughing , also its slowly turning itself to dust from machine vibrations,
What program is that you speak of Phil? Vectric ?
Definitely one of a kind! Well thought out …
Great stuff!!
Great work, are you using magnets to hold down the top? If so, glued in, or press fit?
