Is it just me or is anyone else frustrated when selecting an item to edit. - Just the simple left click of the mouse button can slightly move the item. How do you prevent this? Is it possible for inventables to add a key hold down command that temporarily prevent mouse movement input while left clicking to select an item?
When you get it in place you can pin it so it will not move.
What Mark said !
To add to that, the pin option must be turned on, go to machine >general settings and you can turn on pinning ,I think there is a help section about it as well under the help>features section… I thinknits there, not sure though.
Thanks for the tip
Thanks! Didn’t know that feature existed.
