Multistage Easel Projects
Not sure if this is a thing in other programs but it would be really cool to program in multiple stages into one project. My example is this, lets say I want to make an acrylic sign that has both tight corners meaning it would take a small endmill to mill them but the sign also has big wide open areas that need to be milled as well. Sure you could use the smaller bit for the whole thing but that would take forever. If there was a way to tell easel that it will run the project with the bigger endmill first then pause as you change it out for a smaller one and it only goes back and finishes where the other endmill couldn’t get to.
Thanks for the tip. I guess I’ll just have to wait to get access to the beta.
