This is a relief carving with everything carved into or around a saw blade shape. It has been published to Easel.
After creating the carving in Easel I deleted all parts except for the text and ran the program with a 1/16 inch bit carving the text.
I then carefully changed the bit to a larger 1/8 inch two flute bit and added everything back into Easel using the undo tool and then removed the text. When I ran the program again It carved the background away from the saw blade.
Please use it any way you would like.
