My test to carve & etch glass with the X-Carve
I can not seem to get the vidio to run. I watched it the other day and it was fine. I wanted to see it again I was under the impression the router was running but sort of what i have seen on here it sounds like it was’nt.
Phillip the movement is ± 1mm is only for the movement of the pressure of the xcarve over the glass (sorry for my bad english) I use the bit without movement to use the “scratch way”. I did another try after this and get better things! This way work really!!!
Thank you
Looking through the glass :wink: someone gets some serious use out of their X-Carve…judging by the use of that waste board.
That looks great!! Good job!!
Great!
hahahahaha yeahh i used it until I need waste it!
