Need help from the grbl experts
After a week of upgrading my x-carve I finally got to play with my laser and it’s burning as it’s supposed to do. But there’s still one issue that I can’t figure out.
After the job is done the laser returns to it’s start position, but picsender shows coordinates for x and y probably where the laser was burning.If I don’t pay attention and re-zero x and y before starting the next job the spindle moves towards me until it reaches zero.
I remember in the past the discussion about positive and negative workspaces and compiling grbl. But that’s over my head right now.
Following the things I’m using:
  • grbl 1.0c (1ms dwell)
  • j-tech no Z Post processor
  • Picsender 2.7.9
attached are the grbl settings in laser.txt, the g-code I ran and a screenshot after job completion. I also think my homing cycle hits the endstops harder now. Would be great if someone could help me with this.
I hope it’s just changing a value instead of flashing another grbl version.
Edit: Just burned an image with the gcode generated in PEP and the spindle moves back to X/Y 0/0 after the job is done
Settings.zip (131.0 KB)
Change $25=750.000 you have yours set to 7500.000
I have run your G-code on my machine using the same grbl version you have with PicSender 2.7.9 and I do not see the behavior that you describe.
At the end of the run the DROs read X = 0 , Y = 0
Wow Thanks Larry, I knew I could count on you. Totally missed that one, in spindle.txt it’s ok though. Will try it in the morning again. As I edited above after running a gcode from PEP it was normal.
Have a good night and thanks again
