Hi All,
I’m cutting some dog holes in to 4 new workbench tops. The tops are 750 x 1220mm 18mm thick.
I have my 1m x 1m x carve in a enclosure with doors opening at the front. So i can cut about 2 x 3rds of the holes before needing to move the workpiece.
I thought i would put a fence on the Y axis, I thought i would set a small drill action to use as a reference point to rehome the match however I’m going to have to rotate the work to fit it back in. I’m worried that it will loose accuracy.
Any recommendations?
Thanks.
