Need help with the Path Warped App
Can someone please explain to me how you “combine” the text with a shape so I can use the app to arc some text? I know it is going to be a simple process, I just cannot figure it out.
Thanks in advance,
Ed
Hi Ed,
It’s pretty straight forward:
  1. insert another shape, usually I insert a circle
  2. Set the depth of the text to something other than zero, and set the depth of the circle to zero
  3. Select both your text and your shape
  4. Right click and select “Combine” or go up to edit and select “Combine”
