Needing help downloading the easel driver software
Once in easel you go to machine on the top, and then drivers/post processors, and go from there. What exactly is your issue?
Thank you for your help. Since I posted this I’ve discovered that the X axis limit sw on the left is misaligned and won’t shut off in home position. It literally had a screw loose and I won’t know till I get this repaired.
I got the limit sw fixed and when I go to carve it doesn’t seem to recognize the new xy position and goes back to the origional and starts carving in mid air
