NESTING in easel
was looking for a guide on nesting within easel. I could not find anything, or maybe just overlooked. Is there a way to nest? If not, what would one suggest for a nesting software that is reasonable and easy to use? Thanks in advanced
you can check this out,
Nest Parts (vectric.com)
you could export the design as a SVG (Go To Project>Download Project (zip) then unzip the file) then import the SVG into DeepNest.io a FREE software that can perform the nesting function for you. Then let it compute the desired nest and then Re-Save the file as a SVG again and import that back into Easel to setup the toolpaths.
