I would love a button in the shape box that puts your project at 0 0 in the middle. I almost always cut with the start point being the middle. And what is with that suggestion box that pops up every time you change the position. Does anyone use this can you turn it off?
There’s a suggestion box? Can you share about photo?
I select the center dot and type 0,0. Is this c what you’re also doing?
You want a button similar to “center to material” that’s in the edit menu, but instead you want another b that says something like “center to 0,0” ?
If so, I can move the thread into the feature requests topic lmk
