I used this picture but cant get the teeth to show in my detail cut any suggestions ?
Change your bit to a smaller bit, or a v-bit to see more details.
@PatrickMckinley Here is a copy in Easel ready to carve. Take a look at it. I used your image and brought it into Inkscape and did a trace bipmap. Then brought the svg file into easel.
you rock thank you
That worked perfect I will add my text and do a test carve today I appreciate it very much
The real key is to learn how to do this. It is very easy
so not sure what i did wrong but this is what it cut like but detailed view said it should have been good. im sure its something i did any ideas?
How are you setting your Z-zero? Looks too high.
with the z-probe
