Hey there everyone. Just got the X-Carve up and going. A few issues with setting xy to zero with the probe. It went back to center of machine nowhere near the piece i needed carved. Its gonna take some time to get to know this machine but any advice would be a great help. Thanks
The first thing I would check is the 0,0 on the project.
If you have your project set so the 0,0 is on the left corner (like the photo below) the machine will usually shoot up and to the right to start the carve.
Once you know where your 0,0 is on your project, make sure you set the 0,0 on the machine the same way. If you set it on the bottom left corner, then you will want to 0 the machine on the bottom left corner of your material, and if you have your 0,0 set on the center of your project then set your machine so the 0 is dead center of your material.
So i also bypassed the homing device becasue when setting it up it wouldnt stop homing when trigger was hit. I changed homing tab and did the same. So went on and checked if the green light was activating and it was. I went woth the z probe and manually settings. Ill be doing alot of reading here this afternoon to get a better feel of this amazing machine.
