Hi, I’m new to Easel and CNC routers in general - although I do own a 3D printer.
I just bought a Saintsmart PROVer V2 which should come in handy when working on my projects.
A friend created it and sent me the STL file.
I can import it in Easel but when I click Generate Toolpaths I get an error message.
Anyone know what the problem is?
This Project would carve much better as a 2.5D design using a svg or dxg of the design rather than a .stl file.
Because your material thickness setting and you model size for Z are the same you’re getting your current error.
You could decrease the model z thickness by 1mm and then it should create the toolpaths…
