I hope I provide the right things?
my grbl version is 0.9j
and my settings ;
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$3=0 (dir port invert mask:00000000)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.000 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$25=500.000 (homing seek, mm/min)
$100=400.000 (x, step/mm)
$101=400.000 (y, step/mm)
$102=400.000 (z, step/mm)
$110=500.000 (x max rate, mm/min)
$111=500.000 (y max rate, mm/min)
$120=0.000 (x accel, mm/sec^2)
$121=9.218 (y accel, mm/sec^2)
$122=10.000 (z accel, mm/sec^2)
$130=232.114 (x max travel, mm)
$131=-2147483.648 (x max travel, mm)
$181=-2147483.648 (x max travel, mm)
$181=-0.000 (x max travel, mm)
$182=-0.000 (x max travel, mm)
$183=-0.000 (x max travel, mm)
$184=-0.000 (x max travel, mm)
$185=-0.000 (x max travel, mm)
$186=2147483.648 (x max travel, mm)
$181=0.000 (x max travel, mm)
$183=0.000 (x max travel, mm)
$184=0.000 (x max travel, mm)
$185=0.000 (x max travel, mm)
$186=0.000 (x max travel, mm)
$187=0.000 (x max travel, mm)
$188=0.000 (x max travel, mm)
$189=0.000 (x max travel, mm)
$190=0.000 (x max travel, mm)
$191=0.000 (x max travel, mm)
$192=0.000 (x max travel, mm)
$193=0.000 (x max travel, mm)
$194=0.000 (x max travel, mm)
$195=0.000 (x max travel, mm)
$196=0.000 (x max travel, mm)
$197=0.000 (x max travel, mm)
$198=0.000 (x max travel, mm)
$199=0.000 (x max travel, mm)
$200=0.000 (x max travel, mm)
$201=0.000 (x max travel, mm)
$202=0.000 (x max travel, mm)
$203=0.000 (x max travel, mm)
$204=0.000 (x max travel, mm)
$205=0.000 (x max travel, mm)
$206=0.000 (x max travel, mm)
$207=0.000 (x max travel, mm)
$208=0.000 (x max travel, mm)
$209=0.000 (x max travel, mm)
$210=0.000 (x max travel, mm)
$211=0.000 (x max travel, mm)
$212=0.000 (x max travel, mm)
$213=0.000 (x max travel, mm)
$214=0.000 (x max travel, mm)
$215=0.000 (x max travel, mm)
$216=0.000 (x max travel, mm)
$217=0.000 (x max travel, mm)
$218=0.000 (x max travel, mm)
$219=0.000 (x max travel, mm)
$220=2147483.648 (x max travel, mm)
$182=-1.867 (x max travel, mm)
$183=-2147483.648 (x max travel, mm)
$182=-2147483.648 (x max travel, mm)
$181=2147483.648 (x max travel, mm)
$182=1.202 (x max travel, mm)
$183=2147483.648 (x max travel, mm)
$182=2147483.648 (x max travel, mm)
$181=93789.920 (x max travel, mm)
$181=0.057 (x max travel, mm)
$181=-1.419 (x max travel, mm)
$182=0.000 (x max travel, mm)
$184=3.685 (x max travel, mm)
$186=0.498 (x max travel, mm)
$188=2147483.648 (x max travel, mm)
$181=0.008 (x max travel, mm)
$182=-120.531 (x max travel, mm)
$181=0.002 (x max travel, mm)
$181=6959.718 (x max travel, mm)
$181=20923.834 (x max travel, mm)
$186=-0.000 (x max travel, mm)
$187=-0.000 (x max travel, mm)
$189=-0.000 (x max travel, mm)
$194=-2147483.648 (x max travel, mm)
$185=-2147483.648 (x max travel, mm)
$183=-32.001 (x max travel, mm)
$184=2147483.648 (x max travel, mm)
$183=32.001 (x max travel, mm)
$185=-40.016 (x max travel, mm)
$188=-0.000 (x max travel, mm)
$189=-0.002 (x max travel, mm)
$190=3.034 (x max travel, mm)
$191=-0.002 (x max travel, mm)
$192=48.560 (x max travel, mm)
$193=-0.000 (x max travel, mm)
$194=-0.000 (x max travel, mm)
$195=-0.000 (x max travel, mm)
$196=-0.000 (x max travel, mm)
$198=2147483.648 (x max travel, mm)
$190=-0.000 (x max travel, mm)
$191=-0.000 (x max travel, mm)
$192=-2147483.648 (x max travel, mm)
$181=-0.003 (x max travel, mm)
$214=-0.000 (x max travel, mm)
$220=0.000 (x max travel, mm)
$221=0.000 (x max travel, mm)
$222=0.000 (x max travel, mm)
$223=0.000 (x max travel, mm)
$224=0.000 (x max travel, mm)
$225=0.000 (x max travel, mm)
$226=0.000 (x max travel, mm)
$227=0.000 (x max travel, mm)
$228=0.000 (x max travel, mm)
$229=0.000 (x max travel, mm)
$230=0.000 (x max travel, mm)
$231=0.000 (x max travel, mm)
$232=0.000 (x max travel, mm)
$233=0.000 (x max travel, mm)
$234=0.000 (x max travel, mm)
$235=0.000 (x max travel, mm)
$236=0.000 (x max travel, mm)
$237=0.000 (x max travel, mm)
$238=0.000 (x max travel, mm)
$239=0.000 (x max travel, mm)
$240=0.000 (x max travel, mm)
$241=0.000 (x max travel, mm)
$242=0.000 (x max travel, mm)
$243=0.000 (x max travel, mm)
$244=0.000 (x max travel, mm)
$245=0.000 (x max travel, mm)
$246=0.000 (x max travel, mm)
$247=0.000 (x max travel, mm)
$248=0.000 (x max travel, mm)
$249=0.000 (x max travel, mm)
$250=0.000 (x max travel, mm)
$251=0.000 (x max travel, mm)
$252=0.000 (x max travel, mm)
$253=0.000 (x max travel, mm)
$254=0.000 (x max travel, mm)
$255=0.000 (x max travel, mm)
$0=0.000 (x max travel, mm)
$1=0.000 (x max travel, mm)
$2=0.000 (x max travel, mm)
$3=0.000 (x max travel, mm)
$4=0.000 (x max travel, mm)
$5=0.000 (x max travel, mm)
$6=0.000 (x max travel, mm)
$7=0.000 (x max travel, mm)
$8=0.000 (x max travel, mm)
$9=0.000 (x max travel, mm)
$10=0.000 (x max travel, mm)
$11=0.000 (x max travel, mm)
$12=0.000 (x max travel, mm)
$13=0.000 (x max travel, mm)
$14=0.000 (x max travel, mm)
$15=0.000 (x max travel, mm)
$16=0.000 (x max travel, mm)
$17=0.000 (x max travel, mm)
$18=0.000 (x max travel, mm)
$19=0.000 (x max travel, mm)
$20=0.000 (x max travel, mm)
$21=0.000 (x max travel, mm)
$22=0.000 (x max travel, mm)
$23=0.000 (x max travel, mm)
$24=0.000 (x max travel, mm)
$25=0.000 (x max travel, mm)
$26=0.000 (x max travel, mm)
$27=0.000 (x max travel, mm)
$28=0.000 (x max travel, mm)
$29=0.000 (x max travel, mm)
$30=0.000 (x max travel, mm)
$31=0.000 (x max travel, mm)
$32=0.000 (x max travel, mm)
$33=0.000 (x max travel, mm)
$34=0.000 (x max travel, mm)
$35=0.000 (x max travel, mm)
$36=0.000 (x max travel, mm)
$37=0.000 (x max travel, mm)
$38=0.000 (x max travel, mm)
$39=0.000 (x max travel, mm)
$40=0.000 (x max travel, mm)
$41=0.000 (x max travel, mm)
$42=0.000 (x max travel, mm)
$43=0.000 (x max travel, mm)
$44=0.000 (x max travel, mm)
$45=0.000 (x max travel, mm)
$46=0.000 (x max travel, mm)
$47=0.000 (x max travel, mm)
$48=0.000 (x max travel, mm)
$49=0.000 (x max travel, mm)
$50=0.000 (x max travel, mm)
$51=0.000 (x max travel, mm)
$52=0.000 (x max travel, mm)
$53=0.000 (x max travel, mm)
$54=0.000 (x max travel, mm)
$55=0.000 (x max travel, mm)
$56=0.000 (x max travel, mm)
$57=0.000 (x max travel, mm)
$58=0.000 (x max travel, mm)
$59=0.000 (x max travel, mm)
$60=0.000 (x max travel, mm)
$61=0.000 (x max travel, mm)
$62=0.000 (x max travel, mm)
$63=0.000 (x max travel, mm)
$64=0.000 (x max travel, mm)
$65=0.000 (x max travel, mm)
$66=0.000 (x max travel, mm)
$67=0.000 (x max travel, mm)
$68=0.000 (x max travel, mm)
$69=0.000 (x max travel, mm)
$70=0.000 (x max travel, mm)
$71=0.000 (x max travel, mm)
$72=0.000 (x max travel, mm)
$73=0.000 (x max travel, mm)
$74=0.000 (x max travel, mm)
$75=0.000 (x max travel, mm)
$76=0.000 (x max travel, mm)
$77=0.000 (x max travel, mm)
$78=0.000 (x max travel, mm)
$79=0.000 (x max travel, mm)
$80=0.000 (x max travel, mm)
$81=0.000 (x max travel, mm)
$82=0.000 (x max travel, mm)
$83=0.000 (x max travel, mm)
$84=0.000 (x max travel, mm)
$85=0.000 (x max travel, mm)
$86=0.000 (x max travel, mm)
$87=0.000 (x max travel, mm)
$88=0.000 (x max travel, mm)
$89=0.000 (x max travel, mm)
$90=0.000 (x max travel, mm)
$91=0.000 (x max travel, mm)
$92=0.000 (x max travel, mm)
$93=0.000 (x max travel, mm)
$94=0.000 (x max travel, mm)
$95=0.000 (x max travel, mm)
$96=0.000 (x max travel, mm)
$97=0.000 (x max travel, mm)
$98=0.000 (x max travel, mm)
$99=0.000 (x max travel, mm)
$100=0.000 (x max travel, mm)
$101=0.000 (x max travel, mm)
$102=0.000 (x max travel, mm)
$103=0.000 (x max travel, mm)
$104=0.000 (x max travel, mm)
$105=0.000 (x max travel, mm)
$106=0.000 (x max travel, mm)
$107=0.000 (x max travel, mm)
$108=0.000 (x max travel, mm)
$109=0.000 (x max travel, mm)
$110=0.000 (x max travel, mm)
$111=0.000 (x max travel, mm)
$112=0.000 (x max travel, mm)
$113=0.000 (x max travel, mm)
$114=0.000 (x max travel, mm)
$115=0.000 (x max travel, mm)
$116=0.000 (x max travel, mm)
$117=0.000 (x max travel, mm)
$118=0.000 (x max travel, mm)
$119=0.000 (x max travel, mm)
$120=0.000 (x max travel, mm)
$121=0.000 (x max travel, mm)
$122=0.000 (x max travel, mm)
$123=0.000 (x max travel, mm)
$124=0.000 (x max travel, mm)
$125=0.000 (x max travel, mm)
$126=0.000 (x max travel, mm)
$127=0.000 (x max travel, mm)
$128=0.000 (x max travel, mm)
$129=0.000 (x max travel, mm)
$130=0.000 (x max travel, mm)
$131=0.000 (y max travel, mm)
$132=0.000 (z max travel, mm)
$186=-0.531 (x max travel, mm)
$191=-2147483.648 (x max travel, mm)
$215=-0.000 (x max travel, mm)
