Hello Guys, just finish set up xcarve pro, I am using MacBook Air same I use for the xcarve1000.
Computer is not recognizing the xcarvepro.
Any help will be really appreciated.
Thanks.
Thanks.
checked Device Manager to find the COM number May help .
If you had it hooked to a 1000 you probably need to use another com port.
Thank you, I need it to refresh usb port
