OCD Upgrade #2: Reverse Y axis drag chain
This one is still in progress. I got an X-Controller and a nice roller work table at the same time I ordered the X-Carve. It made more sense for wires to leave the drag chain in the back. So I came up with a little hack to orient the drag chain backwards.
A little space is needed for the drag chain to clear the terminal block. So I found some 3/4" M4 screws at Lowes and used (2) #10 bolts on each screw as spacers. I then reversed the first two links of the drag chain so it clears the terminal block.
I’ll update this thread as I reassemble things.
