Is it possible to offset a single curved line on easel
Hi
Have you taken a look at the offsetter app in Easel. Just click on the Lego block and search for Offset.
I have tried offsetter app It will work on a closed object such as circle or box but will not work on a line, Maybe I am going about it wrong. I want to cut on one side of a line, when you go to cut settings it lets you cut inside, outside or on the line if it is a closed object but if it is an open line you can only cut on the line
can you share the project that you’re working with? it’s often much easier to explain the solution seeing the problem firsthand.
